Home Forums Products Stompboxes Pitchfactor stuck in Update mode. Can’t update with either Direct Updater or Update Utility Reply To: Pitchfactor stuck in Update mode. Can’t update with either Direct Updater or Update Utility
#141967
stringbot
    nickrose wrote:
    stringbot wrote:
    stringbot wrote:
    …but hangs up on “Preparing for update. Checking device…”
    Actually I’ve gotten it past that screen to the install phase a couple of time but the install fails around 20% complete, with the same result described above.
    If it always fails at the same point, that would suggest a hardware problem. Maybe there is an error message ?
    There was some sort of message but it wasn’t very specific. I’ll try it again from a different computer and see what happens. If I can catch the error message before it disappears I’ll post it.
