Home Forums Products Stompboxes Simplest MIDI setup for 2 x H9 ? Reply To: Simplest MIDI setup for 2 x H9 ?
#141983
Thanks folks.
Yes I have Aux switches on the way – intrigued by the options midi brings though. As you say probably best to experiment a bit first.
If just using Aux switches is it possible for unit #1 to share its tap tempo with #2 if they are themselves connected with a midi cable?
thanks again
Tim
