Home › Forums › Products › Stompboxes › H9 Max and Windows 10 using H9 Control › Reply To: H9 Max and Windows 10 using H9 Control
December 31, 2015 at 4:44 pm
#142003
gkellum wrote:
lovehifi wrote:
Active switch on mutes everything.
Hm. Well, make sure that you’re going into input 1. If you’re going into input 2 with nothing connected to input 1, that will cause problems with some algorithms.
Oh I did but I think I found the issue. The AC adaptor is bad and when I move the ac adaptor cable the unit cuts on and off . Probably a defective AC adaptor cord or even something wrong with the unit itself. Just going to return it. Sucks after waiting on it and then it being defective. So I am done with it. Thanks for your help anyway.
