H9 Max and Windows 10 using H9 Control
Home › Forums › Products › Stompboxes › H9 Max and Windows 10 using H9 Control
Viewing 5 reply threads
    • #113132
      Hi all. I am having a problem with H9 Control and windows 10. If this if the wrong place to ask I apologize. Any way my new H9 connects fine using bluetooth but when using USB my PC says it does not recondize device. Also when I do open Control it says no divice is found. Are there Windows 10 USB drivers for the H9 Max I have to download or are they avaiable? Thanks
    • #142000
      gkellum
        H9 Control just uses the built in MIDI driver on Windows.  So, you should't need to install any special drivers.
        Could you please read through the section on connecting H9 Control to a Windows machine via USB in the H9 Control manual?  There's a trouble shooting section that addresses most of the reasons why people run into problems connecting an H9 on a Windows machine.  The H9 Control manual is bundled into H9 Control under Settings / Help, but you can also read it online here: https://s3.amazonaws.com/com.eventide.downloads/Product+Manuals/H9ControlManual.pdf
      • #142001
        Certainly will but now have another issue. When bypass relay is selected I get sound. When I hit active it mutes alll sound. I dont know. Maybe this isn’t my cup of tea. I am just running my guitar into input one and output one top amp. Using bluetooth on Pad to control it. Even reset all setting and no luck. Active switch on mutes everything. Think I am over it.
        • #142002
          gkellum
            Hm. Well, make sure that you're going into input 1.  If you're going into input 2 with nothing connected to input 1, that will cause problems with some algorithms.
          • #142003
            gkellum wrote:
            Hm. Well, make sure that you’re going into input 1.  If you’re going into input 2 with nothing connected to input 1, that will cause problems with some algorithms.
            Oh I did but I think I found the issue. The AC adaptor is bad and when I move the ac adaptor cable the unit cuts on and off . Probably a defective AC adaptor cord or even something wrong with the unit itself. Just going to return it. Sucks after waiting on it and then it being defective. So I am done with it. Thanks for your help anyway.
          • #142005
            gkellum
              Ok, sorry to hear that.  If you wanted we could mail you another AC adapter for free;  you'd just need to send an email to support@eventide.com with a link to this forum thread and your address.  But if as you say "you're done with it", that's fine too…
          • #142042
            Just an update. After getting over my frustration I returned the defective unit and have a new one that will arrive tomorrow. Excited because I know what it is capable of and hopefully this new one will work fine.
          • #142049
            Just recieved my new H9 and happy to report all works great. Tried it through my two 1966 Super Reverbs as well as my JVM Marshall. Also used it alongside my G major 2 and everything is working great. I have not even adusted anything yet and I already love it.
            • #142051
              gkellum
                lovehifi wrote:
                Just recieved my new H9 and happy to report all works great. I have not even adusted anything yet and I already love it.
                Awesome!  I'm glad you got everything sorted out after your initial unpleasant experience.
            • #142052
              Thanks. Me too. Curious. Is there a way to power on off the H9 other than just unplugging it? Not a big deal if not.
              • #142053
                gkellum
                  No, there's no power switch.  You just unplug it.
