Home › Forums › Products › Stompboxes › Simplest MIDI setup for 2 x H9 ? › Reply To: Simplest MIDI setup for 2 x H9 ?
Use one H9 as your controller. The H9 can be configured to output a MIDI Program Change when a preset is selected. It’s not in the app so you’ll have to dive into the menus on the box. You can set each preset on H9 #1 to output a PC that will load a preset on H9 #2. You can also tell it not to output a PC for specific presets. With a little planning you can set things up to work quite well and save yourself some pedalboard space.
This is a great piece of advice – i’ve just purchased a Peak Midi controller for basically doing exactly this, but if i don’t need it then that’s great!! Can you or anyone else elaborate on how to get this setup at all? Driving 2 H9s etc…
Just to clarify – are you talking about there being a need for an Aux switch to drive 2 H9s, or can you hook one up to the other via a midi cable directly or something to allow pedal 1 to automatically switch presets on pedal 2 when you go up or down between presets?
