Home Forums Products Stompboxes Expression pedal to H9 Reply To: Expression pedal to H9
#142082
Ok guys…..help still needed. I now have a TRS cable. I have plugged the TRS into the H9, and the 2 mono jacks are in the expression pedal and the other is into a new aux footswitch. Red into the exp pedal. I have reset the parameters to ‘both’ and am using the aux switch to scroll down and the right foot switch on the H9 to scroll up. All working fine there.
But the expression pedal is still in ‘reverse’ ie toe down the value is 0 and heel down, the value is 100.
On the boss pedal there is a trim pot which is currently rotated fully clockwise. If I rotate this fully anti clockwise the pedal recalibrates itself from 0-47-0 (heel down-middle-toe down)
Any further tricks or tips to try?
Thanks
