Home › Forums › Products › Stompboxes › a question to eventide techs….WHEN the android app will be available? › Reply To: a question to eventide techs….WHEN the android app will be available?
After some reading, I found that you can program all the front panel controls to respond to MIDI CC messages:
[RCV.CTL] – Receive Continuous Control Message [RCV.CTL] allows external MIDI Continuous Control messages to be used as assignable controls for the HOTKNOB (any combination of parameters) and system control. The idea is to first select the H9 parameter or function that you want to externally control (Mix for example) and then select either MIDI Bend or the MIDI CC with which you want to control it.
With a program like “TB MIDI Stuff” on your tablet, or whatever is available for Android, you can make your own interface to the front panel and operate it remotely from the H9 with a tablet, control surface, or anything that sends MIDI CC. I think that pretty much covers being able to control an H9 from a tablet for performance – all the rest of the stuff you have to do from a MAc or WinPC that is supported by H9Control. You just need to read that section of the manual, and get a program like TB Midi Stuff for Android, and you’re all set.
