Home Forums Products Stompboxes Expression pedal to H9 Reply To: Expression pedal to H9
#142169
stari wrote:
Hey rsvmark
Just wondering as I’m looking to use an Aux Switch with an expression pedal as well, is there an Aux Switch that you can recommend? I was looking at one online, and was told that the Aux Switch will work with an expression pedal but it will only give me toe, or tip position.
Hi Stari
Those barn3 ones look good but I was slightly confused. Posts above imply the expression pedal value go from 0 OR 100 but nothing in between? I would check that. If you are in the UK try bright onion pedals- they do a really small one with a polarity switch for £20 that other guitarists recommended to me. And definately get a recommended pedal- my boss one works great (now) but it took lots of head scratching to find the solution!
Have fun
