Reply To: Mission Engineering SP-1LF with H9 Max
Home Forums Products Stompboxes Mission Engineering SP-1LF with H9 Max Reply To: Mission Engineering SP-1LF with H9 Max
#142288
gkellum
It would be interesting to know if that expression pedal does work in that configuration.  Just so you know, we did create a document describing a few different possibilities for using an expression pedal together with an aux switch.  This document has all of the options that we know work at the moment.
https://www.eventideaudio.com/support/downloads/using-both-aux-switch-and-expression-pedal-h9
