Home › Forums › Products › Stompboxes › Space Reverb: Tap Tempo in Spring Mode › Reply To: Space Reverb: Tap Tempo in Spring Mode
On the space reverb, when spring mode has tap tempo activated….is it possible to make the decay knob respond to time incrememts, instead of subdevisions? I'd like to use tap tempo in spring mode to set the tremolo speed *only*.
Forgive me if this has been asked before, I tried to do an extensive search and couldn't find anything that answered my question. Thanks!
Unfortunately, for your case, the Spring Reverb always seems to respond to tap tempo both with Tempo Mode ON and OFF. I don't believe there is a way to set the tremolo speed only. Of course, if you only want to use the tremolo, you can turn the reverb out by turning the MIx all the way down.
