Home Forums Products Stompboxes Modfactor + usb = noise? Reply To: Modfactor + usb = noise?
#142552
    I'm afraid it means that you have a ground loop, which often occurs when connecting audio units to PCs. It will probably be helped if you plug your computer and your audio rig into the same power socket.
    Other wise you could try a USB isolator. These are available from Amazon for about $40, but we have not yet tested them (we will shortly).
