Modfactor + usb = noise?
Home › Forums › Products › Stompboxes › Modfactor + usb = noise?
Viewing 3 reply threads
    • #113245
      Trendin
        I’m getting a high freq. noise and and every few seconds a  minor click when i connect the usb cable to my pc.
        Is this normal? when i unplug the usb cable from the unit, the unit is dead silent again.
        Is my unit faulty?
      • #142552
          I'm afraid it means that you have a ground loop, which often occurs when connecting audio units to PCs. It will probably be helped if you plug your computer and your audio rig into the same power socket.
          Other wise you could try a USB isolator. These are available from Amazon for about $40, but we have not yet tested them (we will shortly).
          • #142553
            Trendin
              nickrose wrote:
              I’m afraid it means that you have a ground loop, which often occurs when connecting audio units to PCs. It will probably be helped if you plug your computer and your audio rig into the same power socket.
              Yeah i figured it out later that day. The problem is that most usb isolators give 200ma at best and the mod factor needs 500ma.
              I can always upgrade and replace it with an H9 core 🙂 bluetooth isnt noisy
            • #142557
                The mf is not powered from the usb – it maybe needs a few mA. Anything that isolates the ground and provides a tiny bit of power should be OK.
            • #142559
              Trendin
                Awesome. I’ll give it a try then.
              • #142677
                Trendin
                  Thought i’d let you know that I’ve solved the issue.
                  I got one of these:
                  Works like a charm!!! now my rig is quite and can be controlled from the pc!
                  • #142679
                    gkellum
                      Thanks for letting us know. We'll have to create an FAQ item recommending that device for this problem.
