Home Forums Products Plug-Ins Octavox live MIDI manipulation Reply To: Octavox live MIDI manipulation
#142572
tlongabaugh
    Hi svennysvensen-
    Sorry to hear you're having issues with Octavox MIDI control in Logic X.
    MIDI control of plug-ins in Logic is a bit confusing. You need to create a new instrument track, and select Octavox as the instrument (it wll be listed under AU MIDI-Controlled Effects->Eventide->Octavox). Then, select the track who's audio you want to process in the Sidechain menu in the top right of the plug-in window. Now, if you have the instrument track selected, you should be able to play/record MIDI notes affecting the source audio.
    Let me know if that doesn't solve your issue.
    Best,
    Tom
