Home › Forums › Products › Stompboxes › Wrong preset loaded when powering on H9 › Reply To: Wrong preset loaded when powering on H9
February 16, 2016 at 5:34 pm
#142581
gkellum
kenhan wrote:
It's the latest sw that same with spade time algorithm. So what does hardware problem mean? That I have to pay to get it fixed?
Probably not. If you send an email to support@eventide.com with the serial number of your H9, our support people can tell you for sure.
You double checked the version number of the software though, and you are sure it's 5.3.0[4]? If you go into H9 Control with the H9 connected and click on the Settings button in the bottom menu bar, it will show you what software version is installed on your H9 in the upper right hand corner of the screen.
