Home › Forums › Products › Stompboxes › Making a Space talk to a Strymon Timeline via midi › Reply To: Making a Space talk to a Strymon Timeline via midi
#142605
tstern wrote:
If you set your Space MIDI output mode to "Thru", the Space will receive the messages from the looper and pass them directly through to the other pedal.  You wouldn't need to mess around at all with XMT mapping on the Space; everything just passes through the Space transparently.
I know it’s capable of doing that, I just don’t want to have to rearrange presets on both devices to be 1>1. Would midi thru still need to be enabled to use the XMT and RCV functions? Also would I have to make a full loop back to the looper with midi cables?
