Home Forums Products Stompboxes H9 Control – how are preset lists numbered? Reply To: H9 Control – how are preset lists numbered?
#142751
    Sherman01 wrote:
    Thanks. Was looking for an easy way to manage Preset Lists. Maybe I should just manage my OCD 🙂 After a little playing around in /AppData/Roaming/H9 Control/PresetLists (i’m using Win10 for Control H9) it appears that just carefully renaming the first number of the folder in there, does the trick. I just changed “7 H9 Max Factory Preset List 2014”  folder to “2 H9 Max Factory Preset List 2014” and it appears in the application as L02…
    Occam’s Razor.  I just wanted to add that this renumbering scheme works for User Presets, as well.  The valid User range seems to be U0 through U999.  Preset Lists from L0 through L9999.
