Home Forums Products Plug-Ins Blackhole – bypass ? Reply To: Blackhole – bypass ?
#142798
tlongabaugh
    unguitar wrote:
    Thank you for the good news Tom.
    Yes, Audiomulch doesn't have a bypass option. But I must say that more and more vsts which used to have no bypass are adding it while they are going on with their updates.
    I think that it would be easy to allow the "KILL" switch to be set as it is or as a system bypass, exactly as you can do on your hardware processors.
    On a different topic: can you move the preset folder to a different position ?
    Thanks
    Hi Luca-
    Sorry, I could have been more clear with my wording – we will certainly consider adding a bypass based on your request, but I can't say for sure what the outcome will be. I agree that configuring the KILL switch could be a good option.
    The presets need to be in the default location (~/Documents/Eventide/Blackhole) in order for the plug-in dropdown menu to find them. You can load/save presets from any location using the "Load" and "Save" buttons, however.
    Best,
    Tom
