Home › Forums › Products › Plug-Ins › The #102 Dual Shift Algorithm in H3000 Factory native › Reply To: The #102 Dual Shift Algorithm in H3000 Factory native
Thanks for your answer!
These are great news ![]()
It would be really great if you indeed could provide the data sheets.
“Archaeological task”
Yes but isn’t the H3000 a dinosaur?
Now forgive me but your answer leads me to another question.
Further studying the Programming Worksheets I noticed that the algorithm “Reverse Shift” and “Layered Shift” have also modules that are all contained also in the plugin.
I also noticed that you could also reproduce presets from the algorithm “Layered Shift” (#231 Micropitchshift, #325 Magic)
and from the algorithm “Multi Shift” (#521 Micropitch Slap).
May I then assume that these three further algorithm could be reproduced with the modules included in the plugin?
If yes, may I again ask if you could extend your acheological search to the Data Sheets for these algorithms too? ![]()
Best regards
