Home › Forums › Products › Stompboxes › H9 midi/global settings problem › Reply To: H9 midi/global settings problem
March 18, 2016 at 1:06 pm
#142904
Per wrote:
I have this problem. It does not start up with same preset as I used when shut it down. It also loose some other global settings. Its a bit anoying. Any fix for this. Kind regards Per
What software version do you have installed on your H9? The initial SpaceTime release – v5.3.0[3] – had a problem where it wouldn't save it's settings at shutdown. If you have that release installed, you should upgrade to v5.3.0[4]. Otherwise, you may have to contact support@eventide.com about sending your H9 in for us to take a look at.
