Home Forums Products Rackmount Configuring H8000FW for dual-stereo using ADAT Reply To: Configuring H8000FW for dual-stereo using ADAT
#142907
    ThreeFingersOfLove wrote:
    I need to pester you again about this. From the Routing app I use preset 12 ADAT A-B. At 96 KHz, sending two channels (a stereo signal) of ADAT occupy channels 1, 2, 5, 6 on the H8000-FW. The second stereo channel (again at 96 KHz) occupy channels 3, 4, 7, 8. Is this normal?
    Does the same hold true for ADAT outputs, i.e. the first stereo ADAT output channels occupies 1, 2, 5, 6 and the second 3, 4, 7, 8??
    Hi Yannis
    I'm afraid that the answer is "I don't know for certain." Almost no-one uses ADAT at 96K, and we no longer have any equipment here to test it.
    My documentation says that 4 channels are spread sequentially across the 8 ADAT slots, so channel 1 is ADAT 1,2, channel 2 is ADAT 3,4, etc. The answer to your question really depends on what you are calling the channels. The ADAT outputs will be the same as the inputs – if you are using it in this way, it should be easy enough to confirm.
    Hope this helps
    nick
