Reply To: H9 Max problems – Not turning on sometimes
Home Forums Products Stompboxes H9 Max problems – Not turning on sometimes Reply To: H9 Max problems – Not turning on sometimes
#142911
If you did the factory reset and it still happens, it sounds like a hardware problem. It could also be a problem with the power supply – make sure you are using the right one.
