Home › Forums › Products › Stompboxes › H9 Max problems – Not turning on sometimes › Reply To: H9 Max problems – Not turning on sometimes
March 18, 2016 at 4:44 pm
#142913
nickrose wrote:
If you did the factory reset and it still happens, it sounds like a hardware problem. It could also be a problem with the power supply – make sure you are using the right one.
Yeap, I was using the one that came with it.
I also tried my TimeFactor power supply, but still got the same problem. I’ll probably return it to be safe.
Thanks a lot for such a quick reply.
Awesome customer service right there.
