Home Forums Products Plug-Ins Demos not functioning correctly in Logic Reply To: Demos not functioning correctly in Logic
#142916
SylverWyrm
    Thanks for the reply.  I’m running OSX 10.11.3 and Logic 10.2.2, both the most recent versions.
    After a little fooling around, I found a workaround, but you guys should take a look at it and see if you can duplicate the behavior.  The H3000 plug preset drop down won’t work until you hit “load” and actually load a preset. The Blackhole lockups are random, it seems. I guess the first few times it was just locking up as soon as I started it. Closing the plug in window and reopening it seems to fix it.
