Home › Forums › Products › Stompboxes › Using H9 control to move presets to slots in the H9 › Reply To: Using H9 control to move presets to slots in the H9
I start out with a preset list with six presets. First, I drag and replace the Chorus preset “Liquid Sweetener” onto preset position 2. When you drag and replace, you’ll notice that no other presets in the list get moved. Then, I drag and insert the Filter Pong preset “WubbaWubbaWubba” to preset position 3. When you drag and insert, you’ll notice that all of the presets above the newly inserted preset get moved up by one position. But you can still keep the rest of your presets at their given positions if you delete one of the presets by dragging it off the list. This will shift everything down by one again. I do that with the “Spring Theory” preset at position 4…
Ok gkellum,
I didn’t even know, or noticed, there were two ways of dragging (replace or insert).
Thanks very much, I’ll give it a go tonight!
