Home Forums Products Stompboxes Exp Pedal-Controlled Panner for H9? Reply To: Exp Pedal-Controlled Panner for H9?
#142934
    Here’s one way to do it.  PITCH MIX holds an unusual position in this effect routing.  The downside is that’s there’s a short processing time [running through the delays] that will impact your clean tone.  100% wet MIX; everything else at neutral or minimal values.  KEY and SCALE don’t matter with PITCH values at UNISON.
    Map PITCH MIX to the expression pedal at A10+B0 for heel, and A0+B10 at full toe.  The image above shows the expression pedal parked at mid-throw [equal levels out to left & right].
