Home Forums Products Stompboxes An affordable and easy way to change presets in two h9 simultaneously with a single tap? Reply To: An affordable and easy way to change presets in two h9 simultaneously with a single tap?
#142976
You can send program changes from one pedal to the other using one pedal as the the controller. So when you load one preset it transmits  program change via a midi cable to the othe H9 (or any midi device)
[XMT.MAP] Create a MIDI Program Change Transmit Map
When the Left Footswitch loads a Preset, a MIDI Program Change message can be transmitted from the MIDI Out jack or USB to control an external device – e.g., another Eventide Stompbox, an Eventide Eclipse, an Eventide H8000FW, etc.
To Create a MIDI Program Change transmit map, press the HOTKNOB button to access the MIDI transmit map for editing.
The Left field displays the Preset number (P1 to P99). The right field displays either OFF or the Prg No. (0-127). Default map: Prg No. 0-99 map to Presets P1 to P99.
Press the Left Footswitch to select Preset field (indicated by the flashing Left Footswitch LED), turn the Encoder to select the Preset.
39
H9 User Guide System Mode Press the Right Footswitch to select Prg No. field (indicated by the flashing Right Footswitch
Note: MIDI Program Change Transmit must be enabled in order for the H9 to transmit Program Change messages. MIDI Program Change Transmit is turned ON or OFF in the MIDI menu. Default is OFF.
Note: When an H9 Preset is recalled with a MIDI program change message, MIDI Program Change messages are not generated.
Press the PRESETS button once to back-up one level to MIDI menu. Press the PRESETS button twice to go to top level System menu.
its simple
