Home Forums Products Stompboxes H9 out-of-phase issue in serial loop Boogie Mark IV Reply To: H9 out-of-phase issue in serial loop Boogie Mark IV
#143049
    The fact that this issue is affected by how you turn on the loop suggests that it is an issue with the amp.
    Note that pretty much all digital units may have have phase issues if mixed with a dry signal – this is because conversion and minimum processing will cause a delay of a few thousandths of a second, which can be noticeable. Analog pedals will not do this.
