Home › Forums › Products › Stompboxes › H9 w/ exp pdl – when switching Presets ExPdl values are maxed out › Reply To: H9 w/ exp pdl – when switching Presets ExPdl values are maxed out
April 1, 2016 at 2:49 pm
#143066
I'm going to guess that the MAXed values are saved in the preset. When you load a preset it will ignore the pedal setting until the pedal is changed. So, you should save the preset with the values that you want it to load with.
