Home Forums Products Stompboxes H9 w/ exp pdl – when switching Presets ExPdl values are maxed out Reply To: H9 w/ exp pdl – when switching Presets ExPdl values are maxed out
#143068
nickrose wrote:
I’m going to guess that the MAXed values are saved in the preset. When you load a preset it will ignore the pedal setting until the pedal is changed. So, you should save the preset with the values that you want it to load with.
Thank you. I will go back into the preset and save it with parameters tied to the expression pedal at their MIN value and see if that does the trick.
Cheers
