Home Forums Products Stompboxes Switching presets in play mode w/ aux switch Reply To: Switching presets in play mode w/ aux switch
#143074
gkellum
    knutfin wrote:
    It worked with a midi mouse, though. It did just that. It was just to big. Isnt there a way to effortlessly switch between presets and have access to repeat and tap at the same time with an aux switch.
    Yes, that would work as you want via MIDI because the MIDI Mouse is sending out program changes which is in turn selecting individual presets.  Unfortunately, there's no mechanism to do the same via an aux switch.
