Home Forums Products Stompboxes H9 Aux Switch and Expression help/ideas/setup needed please Reply To: H9 Aux Switch and Expression help/ideas/setup needed please
#143081
    danisev2001 wrote:
    I would like to use the Digitech FS3X Footswitch and the M-Audio expression pedal (http://www.m-audio.com/products/view/ex-p#.Vv_1-qSLTNM) using this this cable:
    There is little real information on this pedal on the M-Audio site, so it is hard to say. Note that they say it has an integral cable, so your Amazon cable may not connect to it. The cable would be OK otherwise.We recommend the Ernie Ball VP Jr. 25k pedal.
    If you use the FS3X with this cable you will only get one switch, so it may be a waste.
    See also https://www.eventideaudio.com/support/downloads/using-both-aux-switch-and-expression-pedal-h9
