Home › Forums › Products › Stompboxes › Timefactor getting crazy › Reply To: Timefactor getting crazy
#143098
    Happily (for us), these issues do not happen a lot, so I can't give you a general rule.
    If the problem is the ribbon cable (we had a bad batch once) , it could most likely be one of two things:
    1) The plug having shaken loose from its socket (easily fixed by "wiggling" or re-seating it).
    2) Faulty assembly of the cable – this can't easily be fixed, and requires a new cable.
