Home › Forums › Products › Stompboxes › How to move presets from H9 to H9? › Reply To: How to move presets from H9 to H9?
April 8, 2016 at 8:52 pm
#143138
amcolan wrote:
One request I have unless it's already possible, is there a way to erase a preset either on the iPad or on the unit without having all the other presets shift upon deleting?
No, not really. You could make a preset called EMPTY and overwrite the preset you don't want with it instead of deleting it.
I'm not sure why you'd want to do this though anyway. Do you know that you can easily insert a new preset anywhere in a preset list and cause everything to shift back up again? In the Edit List screen of Preset Lists, you can drag and drop a preset between two presets and that will cause everything to shift up again. Maybe, that helps with the underlying problem?
