Home › Forums › Products › Stompboxes › Freeze Pedal Simulations › Reply To: Freeze Pedal Simulations
There’s no perfect way to emulate the SLOW freeze variations in the H9. The DynaVerb algorithm comes closest, with fine control over envelope attack and release times. In the dedicated freeze pedal, the middle SLOW toggle position is shaped offline by the SLOW-SPEED INITIALIZATION procedure:
- TOG1 (Up) Fade-In 200 mS Fade-Out 400 mS
- TOG2 (Middle) Fade-In 200 mS Fade-Out 1.0 S
- TOG3 (Down) Fade-in 800 mS Fade-Out 3.2 S
Expression Pedal Heel: DECAY 20.0 S
Expression Pedal Toe: DECAY FREEZE
HotSwitch Off: GATED
HotSwitch On: OMNI-RATIO INF
Expression Pedal Heel: DECAY 5.0 S
HotSwitch Off: OMNI-RATIO 0.10
Here, the Aux Switch -> Expression triggers will operate alongside the automated EG response. The ‘normal’ position will gate or expand on the input-sensitive enveloping. Holding the momentary Aux Switch initiates a long freeze override. HotSwitch is programmed to introduce infinite compression into the mix.
