Home › Forums › Products › Stompboxes › request: Assign MIDI Notes to switches + Tempo on/off as destination › Reply To: request: Assign MIDI Notes to switches + Tempo on/off as destination
hi,
i think it would be great if it was possible to assign midi notes to control the H9 in addition to CC..
/N
Probably not hard to do – the main issue is that it would be hard to specify how it would work. What should a given note value do on each of (maybe) 50 diverse algorithms ? You see the problem. If you have answers, we’d gladly look at them.
well, there already are parameters, that by nature are “switches”, as destinations for incoming CC-s (active/bypass, hotswitch, inc/dec preset, looper functions, etc), so not an issue really – Note data is perfect for those as well, and you could for example congifure the controller to be toggle or gate. This would allow controllers that can’t send CC on buttons..
For knobs it might not be as intuitive, but could still allow people to toggle between values in a fedined range, as knobs are set today, tho it’s not as essential as the obive mentiones scenario..
