Home › Forums › Products › Stompboxes › request: Assign MIDI Notes to switches + Tempo on/off as destination › Reply To: request: Assign MIDI Notes to switches + Tempo on/off as destination
May 3, 2016 at 6:05 pm
#143269
nickrose wrote:
Probably not hard to do – the main issue is that it would be hard to specify how it would work. What should a given note value do on each of (maybe) 50 diverse algorithms ? You see the problem. If you have answers, we’d gladly look at them.
Couldn’t it work pretty much the same as CC? Use the note value of the note-on message in the same way as the CC number and the velocity as the CC value. That way you could (for example) use note 7, velocity 100 in the same way as CC7, value 100. Ignore the note off messages and you’re done 🙂
Mike
