Home › Forums › Products › Stompboxes › Thinking about adding MIDI to my H9… few questions inside › Reply To: Thinking about adding MIDI to my H9… few questions inside
#143271
nickrose wrote:
It sounds like the best answer to your needs is to get a MIDI expression pedal (or a MIDI expression pedal controller) and then use a regular 3 button switch for the AUX. Note that most H9’s do not supply power over MIDI.
I read elsewhere in this forum that MIDI expression pedals sometimes resulted in some lag (delayed response to adjustments). If that’s not the case, are you saying something like this would work since I already purchased the VP Jr. 25k http://www.sweetwater.com/store/detail/MIDIPC
Or any other MIDI controller recommendations considering I already bought the recommended VP Jr?
