Home › Forums › Products › Stompboxes › Thinking about adding MIDI to my H9… few questions inside › Reply To: Thinking about adding MIDI to my H9… few questions inside
Can you confirm that this pedal would work for the VP Jr. 25k http://www.midisolutions.com/prodfsw.htm
It won't. It has the same MIDI power requirement as the other MIDIsolutions product. See my previous comments.
And also, more importantly, can you comment on the MIDI Lag here — is this a real issue?
MIDI is never instant – the thing reading the pedal has to notice a change and then send a message. The H9 has to receive the message and process it. None of this takes very long, but it is not instantaneous. I'll guess and say it might take a 30th of a second – this is not much, but might bother some people.
My guess is that what you are trying to do will probably work better with a connected pedal and a MIDI switch unit.
