Home Forums Products Stompboxes H9 and using Behringer FCB1010 Reply To: H9 and using Behringer FCB1010
#143310
gkellum
    rmarcopolo wrote:
    I have no idea on waht CC, PC SW1 etc do in relation to the H9 and when I read the H9 manual i get even more confused…
    It might be easiest for you to configure the H9s MIDI Settings using H9 Control.  If you connect H9 Control to your H9, click on the Pedal button in the buttom menubar, select MIDI Settings, and select "Assign MIDI CC messages to pedal functions", you'll see under the pedal function "assign expression pedal value (aka HotKnob value)" which MIDI CC value (if any) the H9 has assigned to control its expression pedal patch.  You can go into the pedal function page to change it to whatever MIDI CC value you want.  You should configure it there to match your FCB1010.
