Home › Forums › Products › Stompboxes › Beyond The Frost Line [Freezing H9 MultiEffects] › Reply To: Beyond The Frost Line [Freezing H9 MultiEffects]
This preset blurs the lines between freeze, short looping, & sequencers. Versatile & highly interactive multi-FX.
The initial default – or after erasing the delay buffer – is dry input, plus a small, bright room. Holding down the Aux switch adds a one-shot burst of 4 resonant delay taps. Releasing the Aux switch freezes and latches the sequence into an ‘infinite’ background loop. Playing over the top of that is the dry signal + reverb. Tapping the Aux switch edits the sequence, and also erases it [short hold with no additional input].
Aux / EXP PED Heel: FEEDBACK FREEZE
Aux / EXP PED Toe: FEEDBACK FB:2 1
HotSwitch Off: RHYTHM 1.3.5.7
HotSwitch On: RHYTHM 2.4.6.8
The HotSwitch shifts the RHYTHM sequence as a ‘live’ parameter within the frozen loop. This preset uses the ‘disintegrator’ FEEDBACK mode [FB:2]. Those variations in the background sequence are added to the 1st Aux switch’s high level of control over the ‘captured’ signal.
