Home › Forums › Products › Stompboxes › No audio output when switching from bypass to active. › Reply To: No audio output when switching from bypass to active.
#143348
tsternfeld
    Gav RL wrote:
    Whereas I just wrote this off as a dead rubber. It should work, but it doesn't, so I've just accepted that my H9 won't do what I wanted it for.
    Before you write it off, if you help us reproduce the issue we can potentially find a solution.  As my colleague noted above, zip up an Ableton session that makes it happen, and we can take a look to either resolve the issue or, if it's a firmware bug, fix it for a future release.
