Reply To: H9 midi help!!!
Home Forums Products Stompboxes H9 midi help!!! Reply To: H9 midi help!!!
#143374
gkellum
Sugarlou wrote:
HELP…is there a factory restore? Something happened when I was saving a new set of patches.
There are two kinds of factory resets.  You probably just want to clear out your H9s system settings but not lose you presets.  To do that, turn your H9 off and then turn in back on again with the right footswitch and the HotKnob switch pressed (the switch in the upper left hand corner of the H9).
