Home Forums Products Rackmount Dimension D in DSP7000 Reply To: Dimension D in DSP7000
#143383
    Here is the sigfile, but I can't tell you if it will run on your 7000, or give any further support.
    HEADM adc 2 2 gain-out gain1-out "Dimension D " "" 2 dmenu-obj info-obj ;=75,15,100,0
    TEXTBLOCK info 4 "This preset emulates the Dimension D" "chorus with the four buttons, with some" "added parameters." "Stereo I/O" ;=75,15,100,0
    MENUPAGE dmenu "dimension D params" chorus 3 mode-obj dry-obj g-obj ;=75,15,100,0
    EQ "eq L" adc-in1 70 1 -18 0 ;=75,15,100,0
    EQ "EQ R" adc-in2 70 1 -18 0 ;=75,15,100,0
    TEXTKNOB mode "m o d e  :    %s" mode 4 0 1 2 3 4 ;=75,15,100,0
    MULTIKNOB "depth setting" 1 1 2 5.5 1 0 4 mode-out 2.7 5.35 4 4 ;=75,15,100,0
    MULTIKNOB "delay setting" 1 1 22 30 1 0 4 mode-out 29.3 22.7 22.2 22.2 ;=75,15,100,0
    MULTIKNOB lfo-setting 1 1 0.25 0.5 1 0 4 mode-out 0.25 0.25 0.5 0.5 ;=75,15,100,0
    LFO lfo1 adc-null lfo-setting-out 0 1 0.5 0 ;=75,15,100,0
    MIX "phase rev" lfo1-out adc-null -1 0 ;=75,15,100,0
    MODDELAY delayL 100 "eq L-out" lfo1-out "delay setting-out" "depth setting-out" 0 ;=75,15,100,0
    MODDELAY delayR 100 "EQ R-out" "phase rev-out" "delay setting-out" "depth setting-out" 0 ;=75,15,100,0
    FILTER "high pass 1" delayL-out 10000 2 0 ;=75,15,100,0
    FILTER "high pass 2" delayR-out 10000 2 0 ;=75,15,100,0
    FILTER "high pass 5" "high pass 1-out" 600 1 2 ;=75,15,100,0
    MIX mix1 "high pass 1-out" adc-null -1 0 ;=75,15,100,0
    MIX mix2 "high pass 2-out" adc-null -1 0 ;=75,15,100,0
    FILTER "high pass 6" "high pass 2-out" 600 1 2 ;=75,15,100,0
    FILTER "high pass 3" mix1-out 160 1 2 ;=75,15,100,0
    FILTER "high pass 4" mix2-out 160 1 2 ;=75,15,100,0
    MULTIKNOB eq-setting 1 1 -12 -3 1 0 4 mode-out -12 -12 -12 -3 ;=75,15,100,0
    KNOB dry "dry level: %4.0f dB" knob -100 0 1 -9 ;=75,15,100,0
    MIXER mixer 3 adc-in1 "high pass 5-out" "high pass 4-out" dry-out eq-setting-out -3 ;=75,15,100,0
    MIXER mixer1 3 adc-in2 "high pass 6-out" "high pass 3-out" dry-out eq-setting-out -3 ;=75,15,100,0
    KNOB g "out gain :  %3.0f dB" knob -20 12 1 6 ;=75,15,100,0
    GAIN gain mixer-out g-out ;=75,15,100,0
    GAIN gain1 mixer1-out g-out ;=75,15,100,0
    TAIL ""
