Home › Forums › Products › Stompboxes › H9 Control stops every ten minutes or less › Reply To: H9 Control stops every ten minutes or less
May 19, 2016 at 3:44 pm
#143398
Thank you so very much for th suggestion. I have opened up the OS per your instructions and found about ten or so references to devices that had been told to go into PowerSaving mode and I have unchecked all of these boxes. I will be setting up my equipmnet later today to see how this affects the problem. Again, thanks. This is the professional attention one would expect from a company such as Eventide. You are a credit to the company.
