Home › Forums › Products › Stompboxes › H9 and using Behringer FCB1010 › Reply To: H9 and using Behringer FCB1010
May 25, 2016 at 10:20 pm
#143441
rmarcopolo wrote:
Still cannot get FCB 2nd expression pedal to work.
Ive tried all the suggests above and still no go.
If I were you, I'd hook the FCB up to a computer and double check what it's actually sending out. You can do this with MIDI Monitor on Mac and MIDI Ox on Windows. If everything is configured correctly, there's no reason why this shouldn't work. So, either the FCB1010 isn't sending out the MIDI message that you think it is sending out, or the H9 isn't configured to process the MIDI message that it is sending out.
