Home Forums Products Stompboxes Computer Noise / Digital Noise when H9Max connected Reply To: Computer Noise / Digital Noise when H9Max connected
#143498
karmarilla
    Hello ,
    it seems there must be a ground issue with the moog or my pc …
    I reallly tried everything now – reduced my setup to only pc (checked all usb connections) and moog and the h9 – had even the monitors and screens not connected and still had this noise.
    The strange thing is that is not there when the moog is connected directy to the soundcard.
    When the h9 is between them as soon as i plugin a Audio Cable in the h9 input from the moog or i plugin the power cable in the moog the noise appears (even with the moog turned off).
    i have found a Solution which works for me by using the H9 as a send effect with Dry Audio killed so the audio passes through the soundcard first then to the h9 and back.
    No Noise ! perfect and iam happy with it.
    On the other hand its a little sad that i cant connect it directly.
    I may have to research what else i can do with ground issues .
    @h9controller its not related to a patch on the h9 or moog – it has to do with the physical connection of the devices – i even brought a complete new cable set , gold plated trs ones still same behaviour.
    In any way , thans for motivating me checking my setup which let me find a solution 🙂 !
    cheers
    Rob
