Home Forums Products Stompboxes No audio output when switching from bypass to active. Reply To: No audio output when switching from bypass to active.
#143531
    mmallea wrote:
    I had the same issue in my h9 in my amps effect loop. I am only using input 1 and output 1 on the h9. I ended up changing the routing option from normal to pre post and it all started working. I don't believe I have any special routes set up in the patches. At least if there are I didn't set them. Was late and I was happy to make it work. Will look more into it this evening. Funny tho I have a Timefactor and after an update it started behaving the same way. I ended up restoring from a backup I took at the time to make it work again, perhaps changing that setting in it ( if it exists) would fix it there as well
    After an update it is wise (and recommended) to re-initialize the unit. My guess is that you did not. Apologies if I am wrong.
