Home Forums Products Stompboxes H9 Expression Pedal Help Needed Reply To: H9 Expression Pedal Help Needed
#143562
nosidamde
    Thanks for your reply. This is what I would like to accomplish. I would like to use the Mini X as a volume pedal when the H9 is not active, and use it as an expression pedal when the H9 is active.
    Hopefully that helps clear that up.
