Home › Forums › Products › Stompboxes › H9 Expression Pedal Help Needed › Reply To: H9 Expression Pedal Help Needed
June 11, 2016 at 10:01 pm
#143563
nosidamde wrote:
Thanks for your reply. This is what I would like to accomplish. I would like to use the Mini X as a volume pedal when the H9 is not active, and use it as an expression pedal when the H9 is active. Hopefully that helps clear that up.
When the H9 is not active, it doesn't do any processing. So, it's not going to work exactly as you described. If I were you, I'd just switch the H9 to an EQ Compressor preset set to a flat EQ and no compression when I just wanted to use the H9 as a volume pedal.
