Home Forums Products Stompboxes H9 Phasing Issue Reply To: H9 Phasing Issue
#143695
Leon Todd
    jmansf3 wrote:
    Thanks so much for the responses!! I have been using my H9 in series and this thing is incredible!!! In fact with the space time algorithm I am finding that I might not even need my Boss delay pedal. Just to add I have tried turning kill dry on and it does indeed solve the phasing issue but it also comes with a volume drop that I cannot seem to make up for with the output parameter.
    Is there anyway to adjust the level coming from your device into the H9? This may help. However, as you mentioned, running it in series works just fine as you already have dry analog signal path 😉
